Focus and spot ports with n1mm
K2PO
I'm displaying spots on SSDR using udp data from N1MM on the port designated for spots.
I want to use Focus Helper, but I understand I can't use the same UDP port for both spot display and Focus Helper.
How should I proceed?
(Much of the Focus Helper info is woefully out of data in the community archives. A refresh of documentation in some official form seems appropriate.)
/Bill, K2PO
/Bill, K2PO
Out of data' is a Freudian slip - should be 'out of date.'0
OK - figured it out. Focus Helper can operate based on *either* a spots or a radio UDP port. I defined both in N1MM (checking the boxes to the left for those two), and then identified the radio UDP port to SSDR/Settings/Radio Setup/Radio for use with Focus Helper (since I'd already identified the spots UDP port for the spots integration in SSDR).0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
