BCD whit 2x 144mhz 2x 432mhz is it possibel ????
In my old setup whit HPSDR I was abel to "customize" my owen BCD-code for my controller, and I need BCD code for 2x 144mhz and 2x 432mhz as I am running my station for EME and is reciving Vertical and Horizontel at the same time, that is why I need to have dual code on same band.
So is there any chance that I can get it ?????
I am building up my system and it wil controll 6x transverter 2x 144mhz, 2x 432mhz, 1x 1296mhz, 1x 70mhz
here is a sceendump how I made it in HPSDR...nice and easy
and here my PCB....
73" OZ1CT Ben
Best Answers
  • HI Len
    I have My board running as a BCD-board and also as BIT-cable so that is not the problem... here a picture of the test setup whit a FTDI-232 board and testing channel "A" (14 output)...all out put is whit a ULN2004
    for my request is the problem is that I ned 2 "BCD-adress" on 144mhz and the same on 432mhz and you only have 1 . Here in OZ-country we do not have 222 or 902 mhz so it would be nice if I can figure out how to edit the band info
    here the "old VHF-BCD-plan"
    and here my request ""New-VHF-BCD-plan"
    But if there is no possibility that you can change it in smartSDR (hope that Flexradio programmer reads this) then I have to find another solution .... possibly with an Arduino or similar.
    It should just be so that everyone could build this circuit easily and simply ... without the use of processor circuits was my thought.
    73" OZ1CT Ben
