How do I open profile manager? When I click the manager doesn't open.
I suspect that the window is off screen which can happen when you change your monitor configuration. The easiest way to recover this is by resetting the SSDR.settings file by deleting it from the "%APPDATA%\FlexRadio Systems" folder and restarting SmartSDR.
2
Profiles does not manage profiles from the point of manipulating settings. That is done from the radios settings only. Saving and naming these profiles is were the actual profile exits. You MUST export your newly created profile to memory, for it to be available in case of loss of profile, due to a factory reset for example, at which you would import the needed profile. It does not get automatically saved as persistence settings do. So it is a two step process to be permanently save a profile.
Hi Bob:
My "GUESS" is that one of the security apps on you PC is stopping the Profile Manager from opening. Maybe someone more familiar with PC security apps can help you.
Gayle K0FLY
That is a good point.....👍
[{"insert":"I'll turn off malware bytes and McAfee and see what happens.\n\nBob KG5MQQ\n"}]0
Turning off the antivirus and malware bytes did not help0
I had added an additional monitor, I deleted the ssdr.settings file and restarted SmartSDR and it worked.
Thank you,
Robert KG5MQQ0 -
Robert:
Thanks for the feedback, good catch. That is some thing to keep in mind for the future. I know that when I added a second monitor, Windows messed with my USB ports, then my second hard drive was lost until Win 10 found it several days later.
Gayle K0FLY
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
