How to best way to add two transverters to Flex 6400?
Thanks!
JR
I do not have a direct answer to your question. Downeast Microwave use to make a interface device to allow both 2M and 70cm transverter on a single XVTR port. I am not sure if they ever made a 2M/220 version. Additionally, I am no longer sure if Downeast Microwave is doing any business at all. It seems they have passed some products over to Q5 signal and that company has a few interesting products.
If you really deeply into VHF/UHF with your Flex and you have extra $'s looking for a place to go you might consider spending alot more money for a lot more capability and buy one of their multiband transverters.
A phone call to either company might yield a solution but I suspect your fall back of a manual switch would be the least expensive and quickest solution.
Of course you could also purchase a used 6300 and run the 220 transverter on it or upgrade your 6400 to a 6600 which has two XVTR ports. I suspect you already know this but thought I would mention it anyways.
Good Luck, John K3MA
Thank for your reply John!
Actually I saw the Q5 transverters and I even considered to buy one from then. But in a second thought I dismiss this idea. I will use 99% of the time in my local repeaters (one in VHF and another in 220MHz). These Ukrainian's transverters are good enough until 5W and I just need 100mW for the locals. I´m just asking if someone have any advice for connect both transverters in a easier way than using an AB switch.
730
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
