RF Gain control doesn't work with SmartControl
If I create a separate session with its own slice on the Maestro (non SmartControl) then the RF Gain control there does operate, so this seems to be a SmartControl issue.
This is a software defect that will be addressed with the next release of SmartSDR v3.
6
I don't have an external Maestro Andrew, but I do have a Flex 6400M and I just noticed that when using the 6400M in SmartControl Mode I am unable to change the RF Gain on the windows SmartSDR Client. This prompted me to come here and see if others have had this issue. I was happy to see your post, but discouraged no one had replied back to it. Do you have any further info on this Andrew?
May be a good idea to submit a helpdesk ticket so that the issue gets logged and prioritized.
Len, KD0RC
I just checked mine and it works fine. Any reason you haven't updated to v3.1.12?
Ed KA9EES
Sure is. What made you assume I'm not running it?
This is still not working on the latest version of SmartSDR v3.74
Not ever worked for me on a 6400M. I reported this in 2021 and was told it was known defect. I think it gets repeatedly overlooked in SSDR updates. But if the slider did not exist, I would not miss it.
I'm running 3.7.4, and it still works. No trouble.
I am on 3.7.4
+32db gain
but in SmartControl
Slider is at minimum and moving it does nothing. So actually plenty of trouble until we learn your secret!
I stand corrected. On the front of the rig, you all are correct. It doesn't work. Yet on the PC it works fine. I run in SmartControl mode 99.99% of the time. I only use a couple knobs and buttons on the rig.
This is SMART-10318 for reference
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
