High noise level until transmit
Hi all,
A friend of mine has a nice SteppIR beam next to his home. I've brought my Flex 6300 over for test and also he has an Icom 7300. We've noticed something rather interesting:
On 20m yesterday we were looking at an S9 noise level pretty much across the band. This was with his SteppIR beam tuned to about 1:1.
He transmitted on USB voice briefly giving his call and the noise level AFTER transmit dropped to like S4.
Then over a period of 5 minutes it began to creep back up to S9.
We put the flex inline and saw the same behavior.
We have tried different pre-amp settings and he has a good station ground. We are scratching our heads on what is causing the high noise level.
I have 20m in my car and tuned it up in the driveway and saw roughly the S4-5 noise level I would expect.
I suspect some kind of a ground loop perhaps but the disappearance of the noise after transmit is puzzling.
Anyone have any ideas?
Hi Mark, I would suspect a bad connection somewhere. Once a little (or a lot...) of current flows through it, the connection "corrects" itself for a bit. I would unplug/plug in all connectors and loosen and retighten all ground connections. If that is not it, take a look inside the SteppIR to see if there is a loose or corroded connection in there.
To verify that it is the SteppIR (or one of the connections to it), try a different feedline and antenna, even if it is just a temporary wire.
Len, KD0RC
It's a problem in the antenna system
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
