Panadapter Question
tpetruzzellis
Greetings:
I have a Panadapter question.
On 40 Meters only --I do not see the gray signal baseline between above the waterfall.
How do I get it back for 40 meters?
thanks in advance
Tom
WA2ANG
thanks in advance
Tom
WA2ANG
On the right side of the Panadapter display you will see a vertical set of numbers designating signal levels below zero dBm. Place your cursor over the above mentioned numbers, left click and move the cursor up, That should bring the base line back up and into view.
Gayle
There are also some little up/down arrow points above the db scale. These change the scale. A combination of those and the suggestion from Gayle should get you going. Good luck!
73, Mark K5XH
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
