Slice A and B audio levels
George M.
Hello
When I activate a second slice on the same band the audio is lower, even if I delete the original slice the audio stays lower.
IE slice A audio set to 50 slice B audio set to 50, slice B always stays a lot lower in level even if I delete slice A.
Am I missing a setting someplace, or is this normal?
Setup,
Smart SDR v 3.1.12.51
Flex 6600
George N1naz
Setup,
Flex 6600
George N1naz
Are the equalizer settings the same? How about the AGC, NB, NR, etc?
Bob, WK2Y
Yes all the settings are the same, triple check them all.0
Just to be clear this is activating a new Slice on the same band not a new Pan Adapter on the same band. Opening a new Pan Adapter the audio levels are the same between them.0
This is nothing new, it has be a problem for a long time. If you search the forum you will fine it has been talked about before.
It needs to be fixed!
A work around was recommended. Change the mode of the slice with low audio, then change it back to the mode you want.
73.. Ken - VE5KC0 -
Thanks Ken for the info, I did do a search but came up empty, I will try again.
George
Tested on 6500 with current V3 S-SDR and two slices on same panadapter have same audio level.
_..--
Tim - k3Tim/7
Thanks Again Ken, changing the mode back and forth makes both slices the same level, and yes it needs to be fixed
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
