SDR v 2.4.9 to preserve profiles. How to update just the DAX drivers?
Using SmartSDR v 2.4.9 to preserve profiles. Is there a way to update just the DAX drivers to avoid Windows 10 updates interference, while maintaining the v 2.4.9 SDR?
Thanks for any instructions...Mike, K6DRY
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Google flex radio Dax drivers. The reinstall is the top item.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I agree with Dave, you should upgrade to 2.4.10. If I remember correctly 2.4.10 also includes the updated DAX drivers.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Yes upgrade to 2.4.10 BUT to answer your question you can't MIX different versions of SmartSDR and DAX and CAT.
    I tried it a couple weeks ago and no go as CAT and DAX couldn't see the radio and since then there has been comments to this here on the reflector and FLEX did comment on it.
