I have a copy of the software. Working on win 10. Your email?
Bob W5TX
Behringer CMD Micro DJ Midi Controller for use with Flex 6000
Has anyone Done a video on how you set everything up regarding software and how you run the program ?? the only thing I've seen so far is Willian showing the software running on this video https://www.youtube.com/watch?v=T6g8AbS69Kg&t=13s the only thing I can done once I've loaded to software i.e. with out the picture of the CMD Micro showing on the screen so your not sure really if the software is working IS PRESSING THE PLAY BUTTON and the Flex 5300 goes in to TX but after a few presses the software crashes or what part has loaded, So anyone still using there CMD Micro with the Flex6** radio and can show how it all works after setup???
Thanks Rob
Rob I had mine working great with Flex 6500 set up on the Lan and the CMD hooked to the LAN.
I moved to Florida and set my radio up to be remote. This is over the WAN. When I tried to get the CMD to work I have no luck . I have been told I need to set the radio up on a VPN but I need to find out if that is the only way. I liked theCMD better than the Mistroe.
i would love some input on this also.
Dale
So No One is using the CMD DJ Micro any more with there Flex 6000 radio's it was looking real good when the FULL program was out there but nothing any more really sad.
[{"insert":"I use it with mine. But my copy of the software is messed up because I downloaded the Programming IDE to tweak the settings, but now the file is like 100mb plus. I don't properly know how to use the IDE yet. I know there is another gentleman who is looking for a copy, too.\n"}]0
Hi Jason thanks for the reply again, I'm not sure what the Full Program look like i.e. what's in the full zip file but the one I've tried on windows 7 64bit does not load up with the picture of the cmd midi just like the picture on william's video, if I can get the program to load to this point then I think it should work, this is why I think I don't have the Full Program i.e. CMDMicroFlex6k_v2_0.zip so if anyone still has the Full version please let us know as there are still a lot wanting to get there CMD micro midi working with there Flex 6000
Rob
Been traveling so could not answer your request. Need your email. Folder contains 96MB.
Bob
w5tx@verizon,net
The software works with smartlink?
message and e-mail address sent to you BOB thank's for the reply
Rob
M0AOV / LZ2AOV
I'd like to try the DJ controller with your program. Could you share it again because the DROPBOX link is no longer available?
Yuri - Ha4Fb0 -
Gyorgy
I need your email address. Email me at w5tx@verizon.net. I’m traveling so may take a few days.
Bob W5tx
Bob
Thanks for the help. I wrote a letter to your email address.0 -
Gyorgy
I lost your email address. Please send again as I am back home and can forward files.
Bob W5TX
[{"insert":"I finally got my Beheringer CMD Micro Midi-Controller working again with my Flex 6500. It used to work few years ago - then stopped. Tried all sorts of things for a long time, and finally have it working again (although some numbers on the Behringer PC image displayed - do not update).\nSolved the problem by first using the JAVA delete program to delete the existing JAVA on my PC. However, that still did Not solve the problem. So next I had to go into the DOS windows prompt and search the hard drive for any remaining JAVA files. There were lots of them left on the drive and I deleted all of them. Was concerned that would effect something else on my PC - but it did not.\nNext I obtained a copy of the program labeled \"CMD MicroFlex 6k_V2_0d\" from a friend. It had two file folders - 32 bit and 64 bit, both contained compressed files.\nLoaded the 64 bit one on my Windows 10 PC and decompressed it. Started up my Flex 6500 application, and plugged the CMD Midi-Controller into my PC. Finally clicked on the uncompressed application. The program ran and while loading got a security alert from Microsoft Widows that there was a security exposure - do I want to continue? I selected continue anyway and the Beheringer came to life, image of the controller appeared on my PC screen and it worked with the Flex 6500 again.\nApparently what caused it to stop working originally - was a JAVA update. The newer versions of JAVA deleted some items and apparently fixed whatever security issue Windows warns of - but that also killed the Midi Controller working with the Flex 6500. \nI had about given up completely and made this one final attempt to get it working again. Thank goodnes I did. Nice to have this ability again to change things without the mouse.\nBob, KE0JJ \n\n\n\n\n\n\n\n\n\n"}]0
So have purchased a NEW CMD micro and need whatever software needed to run it with my Flex-6500 that is running version 3.2.39 software...anyone able to assist? Email is: w4jcwjohn@gmail.com
73 John/W4JCW
I am trying to get mine going again has anybody got the software . I have win 7 pro and win 10 just want it to work . Been off the air with multiple illness .
Dale,
support for midi devices such as your Beheringer is built into SSDR for apple devices. No extra software needed If you have an ipad, iPhone or Mac that you can run SmartSDR on.
flyham
Does anyone have the Software that it will work under windows? Thanks
Bob W5TX
dl4rce@darc.de
thanks!
Ant chance you could send me a copy thanks roger na4rr
I would be curious to know which software we're talking about here.
CmdMicro Flex.zip
CMDMicroFlex6k_v2_0d.zip
FlexMidi.exe
CmdMicroFlexController.exe
Something else?
CmdMicroFlex6k_v2_0d.zip
Did you need a copy?
Roger, if you want a copy,I need your email. Any others?
No, but thank you. I have that and was trying to determine if there was another app out in the wild.
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 156 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
