SO2R 2BSIQ Glitch
Steve London
I am testing a remote Flex 6700 with 2BSIQ operation and have discovered a glitch in the audio. To mitigate audio latency, I am using a RemoteRig and a separate internet connection to transport the audio. I am sending audio from slices A and B continuously, on separate stereo channels. At the control location, I'm using a YCCC SO2R Box to manage the audio streams. All of that works fine with N1MM+.
The problem is that after transmitting on one slice, then switching to transmit on the other slice, while continuing to listen on the first slice (with FDX enabled), there is a significant audio dropout of several hundred msec on the first slice just after transmission starts on the second slice. This makes it unusable for 2BSIQ operation, as that glitch wipes out a character of the callsign being sent on the first slice. This is 100% repeatable.
Is there any solution to this ?
Steve, N2IC
2BSIQ: See https://www.qsl.net/ct1boh/2bsiq/
Steve, N2IC
Steve,
why do you need YCCC box?
I used RemoteRig for CW and audio as well, and all working good.
yuri
N2TTA
Too much audio latency when using SmartSDR for audio.
Steve, N2IC
I using SmartSDR together with Maestro for Flex control only, and Remoterig for transport audio including CW and SSB mic., since Remoterig has less latency. All worked fine here. Flex support Open Two Radio Switching Protocol and YCCC box not necessary. You need to play with delay adjustment and im not sure that will be possible in YCCC SO2R box.
Yuri
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
