Which antenna selections should I select when using a 2M/440 transverter with 6400M?
I have a similar question. I am also using a UR3LMZ 144 to 28 Mhz transverter with a split IF. I bench tested the transceiver and it is spot on. But I cannot get it to work with a MAESTRO based Flex 6400. The UR3LMZ device wants to work into a split IF. How do I set up the Maestro/6400 for a split IF. The only port active on the 6400 is the XVTR port. The RX IN port is dead. How do I make the RX IN port receive active.0
Set the RX antenna on the slice to RXA on a 6400. Or either RXA or RXB on a 6600.
Today I received my UR3LMZ 432/28 Transverter for use with my 6700. I have it working on receive and it is really doing well. Antenna port is selected per slice, when using split IF. I have had the 6700 up on 2 meters for a few weeks, using an LDPA to drive a VHF/UHF auto switching amplifier. I will now be integrating the Transverter into the mix, and is a little more complicated, in that drive levels have to be matched so as not to over drive each following stage. Also integrating in switching to allow me to select which band is used for transmit or receive or TX/RX single band operation. I plan to do some satellite work as well as local repeaters. I have not tested the UHF side of all this, and I hope it works as it does on RX, right now. With the 6700, it is wonderful to be able monitor up to 8 repeater or satellite frequencies at the same time! Having lots of fun with this. But even though I have been doing this stuff for more years then I care to admit. I am still capable of making **** head mistakes. I burned up to LDPA modules because I refused to listen to that little voice in my head, that said, use a reversed diode on the relay to keep the coil from killing your electronics. Well all is now happy, not withstanding my **** head move. When I get further along, I’ll post pictures on QRZ.com.
Upper Panadaptor is the UHF Transverter repeater signal bottom one is is a linked VHF repeater.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
