how to activate vox on maestro
W2PP
Member ✭✭✭
How do I activate VOX on the Maestro? I don't see anyway to turn it on or adjust it.
Peter
Peter
Never mind, you click the power/mic button in, choose your mic, in my case mic 2 since it plugged in the back, voila there is a metric to turn on VOX and set the sensitivity.
Peter0 -
One oddity. When I went back to Smart SDR VOX wouldn't work at all. I had to go in, choose any thing other than MIC, then go back to MIC and it started to work again.0
One thing you might consider is setting up one of your function keys for VOX. It lights up so you know its on. This helps since Flex does not have a VOX indicator on the display.
Pete, I was looking for the VOX setting and cam e across this support page
Thanks for the tip
73's
Paul
GW4AMZ
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 305 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
