Is it possible to upgrade a flex-6400 to a flex-6600?
I don't know if the physical hardware can be upgraded. If it can, I would think it would cost at least the difference in price to do so. One might also wonder if the reliability would be as good as one built from scratch. Flex accepts trade-ins for upgrades and you might be pleasently surprised at what they offer you for your 6400. At least worth an email to check I'd think. You'd also receive the current s/w license level and a new factory warranty. Something to consider anyway ..
Good luck and 73!
Russ KR6W
Contact sales and they will do a trade with you.
mack
W4AX
Is it worth the upgrade ? It depends on how you like to operate. Each works well as I have both models.
If you like diversity receive, two independant SCU's (receivers) SO2R operation, 4 slices, antenna tuner standard, faster processing with direct sampling (almost twice as fast) and other features then then the upgrade is worth it.
If upgrading
Check out trade value vs selling outright.
Have fun deciding.
Bob KC9RF
YES. It is possible, I did it.
Trade in the 6400 and buy the 6600.
The question that I con not answer is if it cost effective. For me it was. Flex gave me a great deal on trade in of the 6400 and the 6600 is everything I wanted. I can use a 2m or 70 cm transverter on one SCU and HF on the other SCU at the same time, or both transverters at the same time.
It was a worthwhile upgrade for me. You will have to work out the economics based upon your needs (and wants).
Jeff0
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
