MMTTY, N1MM, Flex6000 - Not Decoding ??
Running Flex 6600, Win 10 PC , MMTTY v1.70 and latest update of N1MM.
Have Flex in RTTY mode, have double checked for correct DAX settings in MMTTY sound card tab ( dax audio1 & dax audio tx), baud rate at 45.45 and mark/space 2125/170 in MMTTY setup.
Am able to TX just fine, and am hearing what sounds like proper rtty audio but not seeing the correct twin traces on MMTTY spectrum scope or in the Flex spectrum display and not decoding.
So have seem to have missed something in the MMTTY setup that I can’t find. Anyone have any ideas on what to check?
Paul W2eck
Cancel the question: problem solved. Not exactly sure what did the trick, but kept going over settings in N1MM & MMTTY and voila- MMTTY started behaving, properly and started decoding. Not really sure exactly what did the trick, but bottom line fixed.
73 Paul w2eck
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
