New Discussion -- New Idea -- Ask A Question
The explanation for how to "ask a question" and how to post a "new idea" is described in the message board announcements but it seems like the actual interface could be improved. Instead of having to click on the DOWN arrow on the "new discussion" button, could you remove the arrow and add 2 new buttons? I think this would be more obvious and intuitive and avoid mis-classifying some of the posts. Example below.
BTW, I added this idea as a discussion since the post said to only enter ideas for SSDR or the radio and others as discussions if I read it correctly.
Regards, Al / NN4ZZ
@Al_NN4ZZ This is not something I can change.
Tim,
Too bad, maybe that is something you could ask Vanilla to do. It would be a good feature and probably be less for you to deal with since people often miss the way it currently works.
Al / NN4ZZ
Actually, after working with the Vanilla development team, this has been implemented.
Good deal, just checked it out. That should make it better for everyone to pick the right conversation, question and idea topic.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 Win10 SSDR V2.4.10
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
