What TCP / UDP ports for the utility?
I'm running a PGXL remotely and would like to run the utility from outside the shack through an SSH tunnel. Does anyone know the ports and protocols that the PGXL listens on?
  • Alan
    Alan Member ✭✭✭✭
    TCP. Port 9008
    Alan. WA9WUD
  • Thanks Alan. Eventually figured that out empirically..
    For anyone else with the same question, I discovered today that there is no easy way for the utility to find the amp unless it can also hear UDP broadcast packets to port 9008.
