What TCP / UDP ports for the utility?
Jeremy Gilbert KC1JZE
I'm running a PGXL remotely and would like to run the utility from outside the shack through an SSH tunnel. Does anyone know the ports and protocols that the PGXL listens on?
TCP. Port 9008
Alan. WA9WUD
Thanks Alan. Eventually figured that out empirically..
For anyone else with the same question, I discovered today that there is no easy way for the utility to find the amp unless it can also hear UDP broadcast packets to port 9008.
- 683 The Flea Market
