Flex 6500 with elad tmate2
KS3RO
Searched through the archives here, and it appears that the tmate2 is compatible with a flex 6000 series radio with the addition of n4py's software. But am confirming that that is all that is needed? There were some references to cat console for the tmate2, but I am not sure if that is still available or even necessary?
I already own the tmate2 for use with sdruno/icom 7300 but am switching to flexradio as that is basically what I turned my 7300 into with add on sdrs and controllers etc. so Im selling off the 7300 and a 6500 should be landing today to takes its place.
Any guidance is appreciated.
Steve
KS3RO
Steve
KS3RO
Can't help you with tmate or N4py specifically .. But When you install SSDR software on your PC , it will also install SSDR DAX ( the audio path from the radio to your modem apps ) and SSDR CAT. I am assuming CAT console refers to SSDR CAT.
AL, K0VM
@KS3RO This post was created as a discussion, but is actually a question where you desire an answer. This topic should have been a Q&A topic, not a discussion. For more information on how to create an Q&A, please see the Message Board post, Using New Q&A (Question & Answer) Feature.
I have gone ahead and converted this discussion to a Q&A for you.
N4PY and SSDR Is all you need. There is a trial version for you to test. Using it with SmartSDR now with the Tmate2.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
