WSJT not receiving signal from 6400.
Hello all,
So I have watched and emulated the Michael Walker video about getting started with FT8 on my 6400. Still no joy. DAX streaming on and on channel 1. CAT ports setup. CAT test is green, however I do not hear a click when activating PTT test. Maybe just one box I am not checking. Any suggestions very welcome... WSJT version 2.1... Tanks, John
@Chris Walker posted this in the FLEX-6000 SIGNATURE SERIES category. This type of post is better suited to be in the Third-party Software category since it is not directly applicable to the FLEX-6000 hardware itself. I have moved your post to that category for greater visibility.
I wonder if you have your windows audio connections set correctly. You've got to tell WSJT where to find it.
73,Ed KA9EES
Thanks Ed. So I do this via the WSJT file>setting>radio? Or another area? If you have a link you can point me to, that would be great! Thanks again Chris
Should be a setting in that area for audio. I would help further now but I am at physical therapy.
Ed
You're gonna have to set it up as a Kenwood ts-2000.
Larry, Thanks for the pic. Yes it is exactly that way. Still no audio per my pic above. Using Windows 10 by the way. I am going to keep working on it till I get it! I feel like there is just one thing was we s not done. Just need to find it... :) Chris
I'll look at mine as soon as I get home, but I think I still set the rig up as a Kenwood ts-2000.
Yes, that's what I use in WSJT and JTDX.
This is how mine is setup.
It's working.
Well... I thought it was working. It's decoding and transmitting, but I have missed something. No RF is going out.
Good it’s working but it is not necessary to use the Kenwood rig. The flex 6000 rig choice works very well
I must have gotten that from an older discussion. It works!
I'm SSDr 2.6.2. TS-2000 has to be used. Flex 6XXX doesn't work. I might need to update WSJT.
Cat test works. PTT test works. Just no audio to WSJT. My computer audio is at medium and of course Flex is AF/RF is up. Maybe I have a COM port wrong...? Dunno. I have set it up exactly the way flex says to do it.... Im still after it...
I’m still on Ver 2.4.9 but I if you are using ver 2.5 and and above, you will need to tick the Tx enable box on the Matrix for each of the bands you are using. Just a thought.
G.L. Winston
Take a look at the ssdr screen make sure dax is active. I'm using the setup for a TS-2000. I needed to set that manually. Even though WSJT was set to use DAX. SSDR wasn't.
Ed
DAX Audio is what controls your TX Audio, check the DAX level in the DAX control panel.
Thanks Larry. DAX RX is good. I keep thinking it is pc related as the Flex and WSJT seem to be setup fine. I have gone through the setup 10 times!! Maybe something in the PC audio is muted? But all seem well there also.... Dunno.
Are you having trouble with TX audio?
Well my TX audio is blue inside the DAX box. Not sure if I am answering your question. Of course I have not transmitted yet. Thanks again for the help. Just no darn RX audio... Im close! :)
- 354 Community Topics
- 619 The Flea Market
- 8K Software
- 8 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 220 FLEX-8000 Signature Series
- 927 Maestro
- 899 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
