No FM with 2MLDPA
AH0U
I hooked up the 2MLDPA and it works great on my 6700 running Ver.3 on alll modes except FM or NFM... when I switch to this mode, the 2MLDPA does not key and there is no output even thought the 6700 keys... any reason for this?? Is there a setting preventing the FM?
Tnx Bruce AH0U
Check your repeater offset. Verify whether you have entered KHz or MHz, and check the manual to verify which is required. (I don't remember off the top of my head.)
Check and see if attached to transverter connector and make sure that in antenna select that tx and RX are both xvtr.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
