PGXL Utility v2.2.10 - Bug or not
Today out of curiosity i decided to click on a History button
User: "image.png"
It took about 15-20sec to graph to show up
User: "image.png"
About 10sec later, I am getting screen below and PGXL utility getting closed
I repeated process several time, some times I am getting the graph, but most of the times below screen coming up.
My PC has 64gb of memory and it is cool around 21% of usage, so I do not think it is a PC Memory issue.
User: "image.png"
Can someone else test it and let me know if it works for you.
Error Message attached as a TXT file
  • I just tried it (for the first time) and it seemed to work fine for me, no issues. I'm running W10 in a VM under MacOS with Parallels, so my setup is even a bit complicated but didn't cause any problems. I only ran the app for a few minutes though. Maybe running it longer fills up whatever memory allocation it has for chart data?
    Justin
    KL2D
  • Sergey KN7K
    Sergey KN7K Member ✭✭✭
    Thank you Justin,
    Can you try click anywhere on the chart? That's seems like what is killing it in my case.
    Sergey, KN7K
  • Hi Sergey -
    Sorry I didn't reply sooner, I'm still getting used to the new forum. hi hi
    I tried clicking around, and it doesn't seem to do much but also doesn't crash the utility. Sorry I don't have any better info for you. I'd try reaching out directly to Ranko at 4O3A, he is usually very responsive.
    good luck!
    Justin
    KL2D
  • Sergey KN7K
    Thank you Justin,
    I posted it on 4O3A forum and waiting for reply
    Sergey, KN7K
  • Tim - W4TME
    The developers are aware of this issue (bug ID G65)
  • Sergey KN7K
    Tim, Thank you for update.
    Sergey
