cwx panel - bug reports and a problem workaround
1. closing popped out CWX panel using ALT-F4 or closing it using the taskbar "[X]" when hovering mouse over the SDR icon results in two runtime errors.
2. when the CWX panel is within the SmartSDR window, the "pop out" arrow is visible in the upper right corner. after popping out the panel, the width of the panel shrinks slightly (the right hand edge is now in the middle of the Incr/Decr CW speed arrows) and the "pop in" arrow is now outside the visible panel area. the panel right and left edges cannot be dragged to widen the panel. therefore, there is no place to click with a mouse to pop the panel back into the SmartSDR window.
3. workaround: to pop out or pop in the CWX panel, set the input focus in the text entry area of the panel (click on the text entry area). then type <TAB> and then <SPACE>. works in v3.1.8 and should also work in later versions so long as the resource order (buttons, text entry boxes, etc) is not changed.
- 0x49 - chris KB3CS
Hi Chris,
Maybe you should consider updating to 3.1.11. I'm running it here and cannot duplicate any of the problems you describe.0 -
already upgraded. same behavior. including the workaround, so i'm managing well enough.
- 111 -
Can you post pictures of what your seeing, Chris0
sure.
^ looks normal enough {version 3.1.11} .. now click on the arrow in the upper right corner to pop the panel out ..
^ whoops. panel a bit too narrow. arrow at upper right corner not visible.
(workaround to reverse the 'pop-out': click in blue text entry area, then type <TAB> and next <SPACE>)
^ next, if you've hovered your mouse over the SDR icon on the taskbar, and then used the close window widget {a red [X]} to close the popped-out panel, then close the CWX function (by clicking on CWX) and then next re-open CWX (click on CWX once more), you get this error box (#1 of 2)
^ followed by this error box (#2 of 2). then SmartSDR crashes and closes.
okay?
I see what you see. I can not re create this on mine. The cwx opens and pops out fine, and I can close it with clicking on cwx.0
i have a full HD screen using the (default; recommended) 125% font scaling.
pop out CWX, pop CWX back in .. turn off, turn on, pop out again ...
if you pop out CWX and then close it from the taskbar (or using ALT-F4) ... then ?
- 23 (base 35) -0 -
Thanks for the details Chris. We'll take a look at this. I entered 2 issues since they probably are not related:
#J8036 Closing CWX form from Taskbar (or Alt+F4) causes crash
#J8037 CWX Window size adjusts to non-ideal size when popped out causing hidden buttons5 -
Chris, I'm looking into this issue (#J8037) and was hoping you could provide your screen resolution to help narrow down the cause of this issue.
okay! i have a full HD screen (1920x1080) and it was set to the (recommended and default) Display "Scale and layout" 125%.
i'll venture you won't see the issue if you set the Scale and layout to 100%
.. = 73 =
It's worth mentioning here that Jessica, being the talented UI developer that she is, has already fixed #J8036 mentioned earlier in this thread. Thanks again for reporting these things so we can make the radio experience better for everyone.
Chris, this is what I am seeing with the details you provided.
I have not been able to replicate the issue you're describing, but we are going to keep our eyes open to any more instances of this. Thank you for bringing it to our attention, and please let us know if this happens again.
5 -
i am presently experiencing the "three red blinks" (boot failure) issue (ticket has already been opened) and will make my attempts to reproduce the issue once my radio is functioning again.
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
- 918 Genius Products
