PGXL Utility v2.2.10 - Bug or not
Today out of curiosity i decided to click on a History button
It took about 15-20sec to graph to show up
About 10sec later, I am getting screen below and PGXL utility getting closed
I repeated process several time, some times I am getting the graph, but most of the times below screen coming up.
My PC has 64gb of memory and it is cool around 21% of usage, so I do not think it is a PC Memory issue.
Can someone else test it and let me know if it works for you.
Error Message attached as a TXT file
I just tried it (for the first time) and it seemed to work fine for me, no issues. I'm running W10 in a VM under MacOS with Parallels, so my setup is even a bit complicated but didn't cause any problems. I only ran the app for a few minutes though. Maybe running it longer fills up whatever memory allocation it has for chart data?
Justin
KL2D
Thank you Justin,
Can you try click anywhere on the chart? That's seems like what is killing it in my case.
Sergey, KN7K
Hi Sergey -
Sorry I didn't reply sooner, I'm still getting used to the new forum. hi hi
I tried clicking around, and it doesn't seem to do much but also doesn't crash the utility. Sorry I don't have any better info for you. I'd try reaching out directly to Ranko at 4O3A, he is usually very responsive.
good luck!
Justin
KL2D
Thank you Justin,
I posted it on 4O3A forum and waiting for reply
Sergey, KN7K
The developers are aware of this issue (bug ID G65)
Tim, Thank you for update.
Sergey
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
