Is their a computer program that works well for CW with 6000 series radios?
For decoding nothing beats the human brain, especially if an operator has a sloppy fist.
Probably the best decoding software is CW Skimmer. Use that with SDR Bridge or Slice Master and you'll be set. Plenty of info on the Internet on how to configure it.
I also like CWSkimmer. I use it with Slice Master. I will say that Skimmer takes some compute power. I recommend getting the trial version first to be sure that your computer is up to the task before you buy it.
Len, KD0RC
For just decoding I use CWGet or fldigi. I run them both at the same time. Between the two of them they do a pretty good job.
roger
na4rr
The advice above for decoding is spot on. Learn the code, practice use the programs as backups when needed.
For sending, I have to recommend FRLogger. As the author and a CW freak I worked **** the CW panel. It does things that CWX cannot do. It's free. Even if you don't use the logging or any other features the CW panel will make you happy if you want to send via keyboard.
Mark - WS7M
I mostly listen, but I do run cw skimmer as well to catch things because my brain doesn't work how it used to. To me it has the best decoding of them all and it helps you find people on the band. There are plenty of people who will QRS for ya as well.
CWSkimmer and Slicemaster are the solution that works here. Skimmer uses a lot of computer resources. Skimmer' decoding capability drops off as signals weaken. 20 word per minute capability is the absolute minimum necessary to work DX. 25 to 30 wpm is the speed of much of CW DXing. Achieving those speeds requires a very significant investment in time. It's an accomplishment worthy of respect. But time spent learning CW is time lost to exploring all the rest ham radio has to offer. To work CW for DX all you really need to know is your call. When you hear your call, the DX is asking you for a contact. Hit your exchange macro and you're in the log. This attitude about CW is just this ham's opinion and not an effort to start any arguments with the CW enabled, all of whom have my respect.
CWSkimmer was great, but I was only able to get it to run for a few weeks. Now when I start it either nothing happens, or it starts but I can't find anyway to get it to decode. I've tried running it through SDR-Bridge and Slicemaster. When it did run, weeks back, it would quickly run out out of decoders. I have a few more things to try but it has been the most frustrating program I have ever wanted to run.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
