New to 6400 ... need help for remote setup
>> It works locally <<
When I try to access it from here using SmartSDR, it sees the radio but cannot connect. Says it needs an update and it needs to be done locally, but Allan doesn't see any update available when he checks SmartSDR via the LAN.
I searched the forum read the manuals and read lots of info. So I am certain that I missed something, hence this posting.
1. Do I need to setup any port forwarding on my remote router? If so, can someone point me to where I can find this info? I read that you can set it for auto but I can't even access any settings remotely.
Note that I remotely manage my present system and I do have port forwarding for my TS-480SAT / amp remote system)
2. When I start SmartSDR, it automatically starts DAX and CAT. Is that needed? In any event, I can't do anything remotely as it says that I need to be on the LAN.
3. I will license SmartSDR v3 once I get v2 running. The plan is for me and Allan to share the 6400. He would access it via the LAN through my router and I would access it via the Internet (Local router & fiber --> Remote Cable modem & router). Note that I have a separate cable modem and router in the Florida station garage and he has a buried CAT5 cable from his home to the garage so we can share my radio network. This way, I am totally separate from his home cable modem/system
4. This being said, how can a remote user fully manage the radio if he is "2682 miles" away? For example, updating firmware, setup, etc.? When I try with v2 it says that it's "not supported at this time". Is it supported in v3?
How do you manage a "far-away radio" remote setup now?
I'll keep on reading and watching YouTube videos but if someone can point me in the right direction that will save me time.
One step closer ... I activated UPnP on my router and I now have the COM ports. However, it still shows the yellow LED and UPGRADE. Now I have SmartSDR v2.4.10. Must his SmartSDR be the same version? I wonder if he didn't have the previous version?
The reason why I ask is because he does NOT see the yellow "pseudo-LED" or "Upgrade". His is GREEN and he can access the radio.0 -
well, not sure how much help i can be, first is a 6400 or 6400M? he will need to setup the remote. in smartlink setup where he configures the user name and password and callsign, there is a spot to set up the router for auto or manual, does he get the green light when he clicks the test button? may have to do port forwarding manually, also i think all have to be on same version software, you, him, and radio, not much im afraid but maybe a little help.
Good luck!
Flex 6400 w/firmware 2.5.1.130
He gets the green light and can access the radio via the LAN.
He has 2.5.1 and I have 2.6.2 so I asked him to install 2.6.2 as I suspect the same as you. (I plan to license 3.x.y once we get it running on 2.6.2)
I configured the router for UPnP and it allocated a virtual COM port.
The problem is that on my SmartSDR, I can't get to the radio as I have the YELLOW "pseudo-LED" and button that both say "Upgrade". He does NOT see that in his SmartSDR.
This is just day 2 of a non-typical setup where I am 2682 miles away from the radio. Learning :wink:0 -
Success !!!
Once he installed 2.6.2 he saw the same UPGRADE message. He upgraded and I am now able to access the remote system.
I'll probably license version 3.x.y in a couple of days.
Latency is "good" (yellow bars ~100ms), not that bad for a ~2680-mile link from San Diego to Palm Bay, Florida.
Question - I wonder if v3 lets you perform remote firmware radio updates via SmartLINK? I can remotely "cold boot" the radio so having the ability to make updates would be very helpful.
the network status on the scale is his internet connectivity, should be green, mine occasionally drops to yellow for a few seconds and then back to green. good luck, hope ive helped a bit, let us know how it turns out
Richard - KI4P
Mine is YELLOW but then again, I am 2682 miles away. Note that even YELLOW, the system works fine.
Follow-up question - When you shutdown SmartSDR, does the Flex automatically turn off (i.e. standby by mode)?
no! not till you push the green button, then its still in a sleep state until you turn off power to it,
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
