No power out and no waterfall signal
Did you try opening a second pan adapter? Can you do a screen shot, crop it and attach it to your reply?
Rechecked power output and is basically zero on Bird meter in RTTY mode (10, 20, 15 and 40 meters) into vertical antenna at 1.8:1 or better SWR.0
Perhaps you need to move the divider up, where the waterfall should start to split the screen, with the waterfall on the bottom.
Place the mouse pointer on the line, just below the signal screen, hold the mouse button down, and move the line up to "split" the screen.
Alan
WA9WUD
Have feeling this is software related. I put in a ticket. Paul0
Hi Paul, go to Settings, TX Band Settings... And make sure that the PTT Inhibit box is not checked for the band of interest. Also make sure that you have the right antenna selected for TX and RX. On the flag in the panadapter, there is a blue ant indicator for RX and a red one for TX.
Len, KD0RC
TX is not selected on slice A. use your mouse to hover over the TX and make sure it is the color red by selecting with mouse. Test by selecting tune for output power
Also check your transmit band selection menu for power selections and PTT inhibit as mentioned by KD0RC.
Bob KC9RF
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
