Announcing the release of SmartSDR for Mac v1.3.9
Tim - W4TME
edited August 2020 in SmartSDR for Mac
Apple has finally released the SmartSDR for Mac v1.3.9 update. It may take a few hours until this update will appear on the AppStore. This update includes the following changes and fixes:
■ Diversity has been added
■ Flex 6400/6600 Brightness control added
■ The Network Stats tool now shows the Radio and Mac IP Address
■ Added the possibility to change the Audio buffer size individually for input and output
■ Improved clicking on slice flag icons
■ Improved FlexControl function assignment
■ Re-Calibrate now working
■ Step Input field now working
■ Bug when entering frequency manually and/or leaving field fixed
■ CAT changes to let RumLOG and others receive Slice updates
■ Fixed a bug where the UI for the equalizer was not updated when MIC profile changed
■ Fixed a bug where for the Flex-6000R no bands were available in the band selection
■ Fixed a bug where the repeater offset could not be entered with decimal point under DSP settings and for Memories
  • K3DCW
    K3DCW Member ✭✭
    This is fantastic, and based upon some emails we exchanged today, I know that Marcus is hard at work on the next version already!
  • K4QXX
    K4QXX Member ✭✭
    Fabulous! This fixed the click issue I was having with the slice flag!
This discussion has been closed.
