Specifying local IP to Subnet
It's not surprising that you have trouble if SSDR or Maestro are on one subnet and the radio is on another. That's kind of what subnets are for - isolation. I suppose you could bridge between subnets (with an appropriate router), but why?
Let us know what you are trying to achieve and why you went with a subnet.
73 Martin AA6E
Unless you find a way to tunnel broadcast traffic from one subnet to the other, you will never see the radio in a radio chooser running on the “main” network. This is the reason remote access via VPN needs to forward broadcast traffic (as in bridging) - the radio needs to be in the same collision domain as SSDR.
Ted VE3TRQ
The radio is in the shop with a lot of other electronics and electro-mechanical devices such as networked 3D printers. All are hard wired. The subnet router has presence in the main network via IP.
I do not see this issue with other devices in the shop. I can get to the UI's of my printers, including video streams, without issue through port-forwarding on the subnet router; hence, my asking about port specification in SSDR Mac.0 -
Typically, when your radio is in a different network from your computer running SSDR, you use SmartLink to connect. You may just be on a subnet, but it’s a different network.
As an aside, It is unlikely SmartLink will reach your radio through two private networks without some proper router forwards and configuration. Your real problem is trying to use radio discovery - it just won’t work unless you see broadcasts from the network the radio is in. Of course you could always sniff the network to discover what broadcasts need to be forwarded to your main subnet.
Ted VE3TRQ
Smartlink works fine, which is what I'm using, for now.0
Yes, if you forward through the external and internal router that will work. But you won’t see the radio on your main network unless your router forwards broadcasts from the radio to your main network, and ensures there is a route back to the radio (which I would assume you have set up)
Something doesn't sound right to me.
I can use Smartlink to access my radio through two routers via defined ports on both routers. Same port definitions on both routers. That involves communication from here to Texas and back into my network to get to the radio.
But, I can't specify the same local IP/port in SSDR Mac to access the radio from my chair. I'm not scanning for a radio. I'm saying, "here it is; follow the IP and port".0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
