Tried to install the D2XX Driver and received a make error
System
Member admin
This discussion was created from comments split from: SmartSDR for Mac v1.3.5 to be available soon.
I tried to install the D2XX Driver and I got a make error (Using Mac OS Catalina 10.15.6). I wonder if anyone else had the same problem. Otherwise, the program is really good.
Hi
If the error you are getting is to with no such file or directory realting to libftd2xx.a then:
the solution would be to make a directory called "build" in the D2XX folder and copy libftd2xx.a into it. Then (provided you have xcode) the Samples programs should compile OK. Poor of FTDI not to correct this in their documents.
I found that on my imac until I installed the latest update 10.15.6, the smartSDR wouldnt show the FTDI devices correctly but now it does and CW Keying is working as expected.
Hope this helps.
73s
Marios
5B4WN/G0WWW0 -
Yes, Marios, that was the error I was getting. I will follow up on your suggestion. 73 de Juan, NA0B
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
