Borrowed 6400
ka9ees
Member ✭✭✭
I have borrowed a 6400 from a friend. He can't recall his login credentials nor his version of the software. I have updated it to v3.1.12. I hope it won't be a problem if I have to go backwards. But I can't use it. It wants me to buy the software. Is there anything I can do before we get it reset?
Ed KA9EES
Ed KA9EES
I can see I should have read the release notes...0
Install version 2.6.2 and use that. The radio is probably only licensed for version 2. When you install 2.6.2 and click on SmartSDR it will want to "upgrade" then ask if you are sure you want to downgrade. Select Yes and then after downgrade you should be good to go. Also, delete the 3.1.12 shortcuts from your desktop so you don't inadvertently run the wrong version software.
Worked like a charm! Thanks a bunch David!
Ed KA9EES0 -
You're welcome!
Have fun playing with the radio. You will love it.
- 382 Community Topics
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
