Borrowed 6400
I have borrowed a 6400 from a friend. He can't recall his login credentials nor his version of the software. I have updated it to v3.1.12. I hope it won't be a problem if I have to go backwards. But I can't use it. It wants me to buy the software. Is there anything I can do before we get it reset?
Ed KA9EES
  • ka9ees
    ka9ees Member ✭✭✭
    I can see I should have read the release notes...
  • David Decoons, wo2x
    edited August 2020
    Install version 2.6.2 and use that. The radio is probably only licensed for version 2. When you install 2.6.2 and click on SmartSDR it will want to "upgrade" then ask if you are sure you want to downgrade. Select Yes and then after downgrade you should be good to go. Also, delete the 3.1.12 shortcuts from your desktop so you don't inadvertently run the wrong version software.
  • ka9ees
    ka9ees Member ✭✭✭
    Worked like a charm! Thanks a bunch David!
    Ed KA9EES
    You're welcome!
    Have fun playing with the radio. You will love it.
