Frequency display covered by SPLIT and TX in flag
This is probably just a computer display setting, but I haven't been able to clear it. It just suddenly appeared. I didn't upgrade any Flex software or change any hardware settings. One day I turned on the computer and the frequency was covered.
Anyone know how to fix this?
There are a couple of things to check, but I suspect that this may be a font issue. Try downloading this font from our download section: https://www.flexradio.com/downloads/napoliserial-xlight-font/. Once downloaded, unzip the .ttf file. Right click on the file and choose Install. Then restart SmartSDR and see if that addresses the issue.
If it isn't a font issue, it will likely boil down to your DPI settings. In Windows 10, these can be found by right-clicking on the desktop and choosing Display Settings. The slider below where it says "Change the size of text, apps, and other items" will adjust the DPI setting.
5
There is also another font that you may need to load from the web site: https://www.flexradio.com/downloads/didact-gothic-font/
Tim, neither of those links to the fonts are active.
Fred
@K9SO Thanks for the feedback. This is an issue with the new web site. I have notified the web admins and it should be corrected soon.
Please let us know when the download is fixed.
Thanks!
@K6HN The download links now work.
Thanks Tim!
FYI Tim the first link solved the problem for my system. Thanks again!
Me too. Thanks again Tim.
K9SO
Fonts fixed my problem. Thanks Tim and Eric.0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
