WSJTX Global Settings
One of Mike's recent videos on setting up Global Profiles prompted me to do just that. Have a number set up now, but wondering what might be the best setup to save in a Global Profile for WSJTX - FT8 etc. Not having any problems with it, but just wondering thru trial and error what others have the best settings for these modes?
73 Paul
w2eck
Hi Ken, 3 kHz is the accepted BW, in my case I set xmt and RX BW to 0 low and 3 KHz high.
for AGC-T I set it wide open, why, because I use the Flatten setting in WSJT-X. Holds the gain steady with no need for AGC-T.
I have never done Meteor scatter, so can’t answer that question.
5
One thing I recommend is to set up a separate Mic Profile for Digital modes. Name it "Digital" or "WSJT-X" or something like that.
Then associate it with the DIGU mode by selecting that Mic Profile when in DIGU mode.
(When you go back to SSB or AM, select the Mic Profile you prefer for that mode, and the radio will now remember the different profiles, and you won't need to keep changing things like MON, VOX, DAX, and other settings when you move between the modes.)
Then configure your Transmit Filter Low-Cut and High-Cut, turn on DAX, and set your MON level for something comfortable for when you are operating digital modes. (high enough to hear when you are transmitting, but soft enough to preserve your sanity.
Add to that a transmit Profile and TX Band Settings table that will set the power output level to your preferred default for using Digital Modes.
3 -
Thanks Ken! I'll try that.
Ken - thanks - a good baseline.
- when it comes to FT-8/4 what found is best for :
- AGC-T
- TX Filter Hi & Lo cut settings
- Do you use different settings for meteor scatter ?
tnx & 73
Paul w2eck
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
