direct connecting Maestro and 6400
K6JV
Trying to troubleshoot birdie problem and eliminating network switches. When attempting to directly connect Maestro to 6400 with CAT cable, only the two slice meters and Menu comes up. I have tried rebooting both devices several times with the same results. Do I need a special CAT cable to directly connect?
You are using a network cable plugged into the Ethernet jacks on each device?
I haven't connected mine directly so I don't know if a crossover cable is required or if the ports automatically sense this and auto MDI-X. Do you have a switch or hub to place in the middle? That would remove the need for auto MDI-X.0 -
The Maestro manual page 7 says you can connect directly or though a switch:
4.2 NETWORK CONNECTION
Maestro requires a network connection to your FLEX-6000 radio. This connection can take one of
two forms:
• A wired connection using the RJ-45 Ethernet port on the back of the Maestro. This
connection can take two forms
o A direct connection with a single wire, one end plugged into the Maestro, the other
end plugged into the FLEX-6000 transceiver. In this configuration, the Maestro and
the radio set up a two-node ad hoc network and communicate across it.
o An indirect connection through a Local Area Network switch. Many configurations
are possible, but typically the Maestro is connected to a 100/1000 BaseT port on the
switch, and the FLEX-6000 transceiver is connected to a similar port. A third agent,
such as an ISP supplied router-modem provides IP addresses to the network
components via a DHCP service.
So I would guess not only reboot but try removing power from both, then reboot and connect together. I ran directly connected for months before my amp arrived and was hesitant to add the switch, but all thee play together nicely.
Hope this helps
Jeff
AA0ST0 -
Thank you.
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
