Flex 6600M on for five days?
Can I leave the FLEX 6600M on for these five days? Should I?
I have WEMO switch to shut off the power supply in case of need.
73 de Juan, NA0B
Best Answers
My 6500 is on almost 24/7. Think of your flex rig as a radio (computer) server. If it isn’t on, it isn’t available for remote access via Smartlink, SSDR-iOS, or via WiFi from other computers in your network. As long as your antennas are properly protected and there is no lightning danger in the area, there normally should be no problem letting it run. Ken - NM9P5
UPDATE:
If you plan to use a WiMo-type remote AC switch, be sure to use a switched relay to activate the radio's RCA REM port for ON/OF switching of the radio.
Use a second Remote AC switch for your power supply. something like this:
But do NOT simply switch the power supply on and off to control the radio in normal use. This can result in switching spikes and transients that could damage the radio. It also un-gracefully turns the radio OFF without letting it save data to the SD Card, which could be problematic.
There are a number of people starting to use NODE RED systems to remote a variety of functions in their shacks.
You may want to check this group out for lots of great information.
5
I'm up 7x24 as well. Except for the line of thunder storms headed my way. Lightning Maps is a great way to watch in real time. http://www.lightningmaps.org/#y=46.1791;x=-79.4048;z=10;t=3;m=normal;r=0;s=0;o=0;b=0.00;n=0;d=9;dl=7...;
Concur with Ken. I've had my 6500 (now 6600) on for pretty much years straight. It is designed as a server, so keeping it on all the time is not a problem.
That said, it's always a good idea to have some way of shutting things down in event of a malfunction or unsafe conditions. A WeMo makes a great **** switch for the power supply. More elegantly (and better for the gear) is a networked switch with contact closures that can turn on and off the rig via the rear panel RCA jack, select a dummy load on a remote antenna switch, and reboot accessories as needed. There are several good ideas around for doing that, many of which are quite economical.
If you are in a lightning-prone area, nothing will save you from a direct hit. Physically disconnecting the cables before you go is probably the safest bet. Unfortunately, that makes it hard to remotely attach them! With good protection and a remote antenna switch to disconnect the rig, you will be good in most circumstances, though. Risk vs. reward.0 -
And a good insurance policy for the other times....1
Ken, I thought you had a special "cloud based" insurance policy with the man upstairs? ;-)
3 -
Me too! Good one, George....0
I wish it worked that way! LOL!0
Thank you all for you excellent advice and thanks to Michael for the Lighting Maps site.
I do a fair amount of travel for work, so this is very nice.
73 de Juan, NA0B
does the screen stay on and active all the time or does it sleep after a while ?0
At this time the Screen stays on all time.
It stays active. Mine is on 24 X 7 and I have not noticed any effects. I do set the brightness level very low.
I have in the past turned on my 6500 when leaving on a trip and no issues. I now use a Wemo switch to turn on & off my radio using the relay kit you can get at Flex site or also on Amazon. This works great and you can turn on/off the radio with your cell phone or other device.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 305 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
