Transmit Profiles Disappearing
I am finding that the transmit profiles I create seem to disappear after powering down the Flex. All that remains are the default that came within the software.
Global Profiles are fine.
So, Am I missing a set or something?
TU
This problem can be a result of running your radio on one of the earlier versions of SmartSDR that was responsible for SD card corruption. Using one of the latest versions, v2.4.10, v2.6.2 or v3.1.12 will prevent future SD card corruption, but they cannot fix existing corruption. You may need an SD card replacement and once you have it installed, NEVER run a version of SmartSDR less than v2.6.2 (with the only exception being v2.4.10) or v3.1.12.
If you feel this is something you need, please open a HelpDesk support ticket.
2
You are not alone....but this does'nt help...1
Actually that helps. At least I know it's not something I am doing incorrectly and maybe something in the software. TU0 -
Same here. Irritating!!!!!
Tom
NA7AA
Hi Tim,
That's the first time I've seen that suggested.
Been trying to figure out what i may be doing wrong.
Running 3.1.12 6600
Under transmit I have checked TX1 TX2 and TX3 all the way down on every band yet when I boot up whatever band I am on will have all three unchecked.
Another anomaly is the power setting for each band does not work/behave as it should. I ended up setting the max power out for the radio to keep from hurting my amp fortunately max power out is a constant that works.
Is it possibly a corrupt SD card doing all of that? If so I will open a ticket.
So let me explain a little bit about how the TX profiles work. When you set the TX Band Settings, it is not a global setting but is TX profile specific. The name of the TX profile is listed in the top left hand corner of the TX Band settings form. So make sure that you have the correct TX profile loaded.
if you verify that you are using the same TX profile all the time and he settings are net being retained (which is different than the values changing), then you may need an SD card replacement.
Thank you0
Well @Tim - W4TME I have discovered that the band boxes for TX1 TX2 and TX3 work fine until I start DDUtil. The strange thing is that the ONLY two things I have turned on in DDUtil are under the Ports Tab I have RCP1 set to COM17 and CWS set to COM19. This causes CW Skimmer to start up automatically when I switch to CW mode.
I use DDUtil for nothing else.
Unless someone out here has an idea what the interaction is between SSDR and DDUtil I suppose I need to ask K5FR.
Hi this is not something we make mistakes, I have now bought a new flex 6400M a month ago and it loses everything I store when I shut off the radio.
Do you leave the power on for a while after you power down the radio?
This is not normal. Please open a support ticket. Thanks
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
