spe amp 1.3k
KB4OIF
Ok. My amp, the SPE1.3K came on just like normal this morning for my net. No problems. Turned the flex on and the amp did not come on like it normally does. i.e. when I power up the flex, the amp comes on. Switch is on in the back of the amp? Ant suggestions.
If you have one of the connection cables built by ExpertLinears there is a dip switch on the amp connector that can be used to let the amp come on when you turn on the radio or not. If so, could it have been bumped into the off position?0
will look at that in the morning with fresh eyes. Thanks
Morning Rick. Sent the amp back to SPE in Tx for repair. The power supply was out. replaced no charge, but have to pay return shipping. I am ok with that.
I set the power levels in the SPE back to where they were before. 10 watts on low, 12 watts on med, and 14 watts on high. The amp kicked out and said I was over driving. I now have them at 8, 10, and 12 respectfully. It does not kick out as bad but I have to be about a foot from the mike. Mic gain is at 40. I do run the processor on DX. Going to run it that way for a while to see if that's the problem. Thought or suggestions are welcome.
I also have the Expert 1.3 and I'm not experiencing that kind of behavior. I'm sure you have double checked your antenna connectors at the amp and any jumpers. I have found that loose connectors can cause this issue. It sounds like an RF issue in the shack...what type of antenna are you using? I feel your pain with this type of issue...
Yeah. I have checked everything that my old brain can think of. Ant is a single band 40 meter dipole. SWR 1.4. no evidence of RF in the shack.
Update . it was the drive power. I am using 5 watts on the low setting on the amp and getting 500 watts out. On mid it's 6 watts and get 850 -950 out. Have not used the high setting as All ,I need is the mid one.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
