New Power Pole Cables
After the recent discussions about power cables using power poles I thought I should replace mine with new connectors and a bit large ga. cable. As one person pointed out, most people do not make the cables to the power pole specs. I don't think I would ever make up enough to warrant buying all the stuff. Actually it could be a nice side biz for someone.
Thanks, be safe everyone K4WH Email k4wh@arrl.net
I bought the official tools years ago.... A really good investment as I have never had an issue with power poles and ALL my DC connections in my shack and vehicles are PowerPoles1
Howard is right. The tools are a good investment. I use them for more than just Powerpoles. Despite having the tools, Powerwerx makes custom cables. I might go to them for the heavier cables. I don't seem to have much luck doing the 10 and 12 gauge wire. I suppose I just need more practice.
Bob, WK2Y0 -
I purchased a ratcheting tool which has interchangeable dies from N5IAW on E-Bay. I originally got it to crimp coax connectors, he also sells dies that crimp power pole connectors as well as a set that crimp the red, yellow and blue terminal lug ends . I have had good luck with this tool, about $36 for the tool with one set of dies, $18 and change for each set of additional dies. The power pole die slots are marked for 15, 30 and 45 amp terminals.
Gayle K0FLY
i soldered mine rather than crimp....
Paul K3SF
Howard, I know you like to pontificate about the virtues of power poles. Other than my 6500 I will not be using them, unless I for some reason get an Elecraft product. The last long long round table when on and on about good vs bad aspects of power poles. On my equipment I like Molex, and I'd even rather a jones connector. ON the power supply end I use molded polarized male and female. Pretty hard to mix up. In the station I always use a terminal ring and nut it down. I have to laugh. For all the years I ran boats and charters I never had an electrical connector failure. Each spring before launch ALL connectors and terminals were removed from where ever they were terminated checked, polished, brushed etc, and then re tightened. No oxidation, corrosion, or dirt could be tolerated. Failure is not an option when you are fishing in the white water or suds, off the New England and Northeast coast. Power Poles would be a joke in the conditions. And yes we also did Lacing which is now a lost art.
If I have to I have a good crimper and could probably do it, I was just hoping someone who does it on a regular basis might want to make a few bucks. Not looking for a freebee. Be well .... k4wh
-1 -
Bob, thanks for the thought. I just checked and yes they do still have the cables for sale, and the prices are really un-fair. Just easier to get it done by people who do it for a living. Then I will feel better that I can get many years of use with no problems. Since the rig has had 3 other owners, and I have had it for 2 yrs plus now. The dC cable is showing signs of the wire pulling out. So its a good time to make up a new cable, and clean up the radio side. 73's Lance L k4wh0
Both FRS and Powerworx have the cables you’d like. I think our local club has a set of tools, so perhaps you can find access nearby you? It is possible to do a serviceable crimp with other tools, but not anywhere as easy and consistently. I’d suggest simply ordering what you need - either a new cable from either source or the parts & tooling to roll your own.1
My brother-in-law fishes for a living on the west coast.. I am certain that he would never allow power poles on his boat...albeit I did install them on friend's sailboats with no issues..
That said, you made a very good point.
All connectors fail if you do not maintain them. Annual maintenance to remove oxidation is a very good idea. I just spray everything with De_Oxit every year to keep them trouble free. Tightening and especially strain relief is also a very good idea1 -
When placing the POWERPOLES on the 10 guage wire for a Flex 6000 does one use the 45 AMP silver contact? Don't know if the Flex 6000's like this larger contact?
I have a 6300 if that makes a difference
All the power pole parts are the same except for the socket for the wire, which is larger for the 45 amp connector to accommodate the larger wire.
Also have the multi-purpose crimping tool which was a great investment.
In my Grab&Go much of the internal wiring is now using RC world XT60 and XT90 connectors which are smaller, gold plated, better surface contact and lock together well. All radio connections are still power pole (especially the 6700). My external battery and shack distribution uses 8 gauge wire and the larger/higher current power poles.
The 45Amp contact have quite a bit thicker and more Spring then the 15 and 30 Amp contacts they do fit the same shell.
You want to solider the connectors after you crimp them with the right crimpers and make sure they will fit in the Shell BEFORE soldiering and solider JUST the crimp part of the contact to the wire by have the connector vertical so the wet soldier doesn't flow onto the contact point and use the smallest amount of solider so the contacts will still fit inside the Shell.
This is how I do mine and have never had a problem, if you can find some, with a toothpick put a very very small amount of silver antioxidant grease on the contacts.
- 113 SmartSDR+
- 920 Genius Products
