Acom 2000A QSK Interface
Sherman Banks
I am trying to hook up the Acom 2000A to a Flex 6400 for QSK. I have RCA TX1 going to the amp's Key In. I have RCA TX Req going to the amp's Key Out. I measured the Key Out output from the amp and it is High on RX and goes low when the Flex keys the amp. My issue is that no matter how I set the TX REQ, whether Active High or Low, the amp will key. I would have expected it to only key when set to Active Low. RCA TX Req is selected on the TX Band Settings.
Am I missing something in the setup?
The T/R sequencing for QSK operation is set by the internal microprocessor in the 2000A (it has a high speed vacuum T/R relay designed for QSK). So no Tx Inhibit should be necessary for QSK operation. I don't think you can overcome that using the Tx REQ regardless of how you set it in the Flex - it will key determined by the amps internal sequencing circuitry.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
