PGXL feature request
Sergey KN7K
Member ✭✭✭
Currently PGXL shows Power on the scale and numerical value, Peak current on the scale and numerical value.
Please do the same for SWR.
Currently SWR shown on the scale only, not numeric value.
I understand there is no filed for the number when SWR is low, please consider to add a numerical value on SWR above 1.3 or so.
Here is a proposal in below image.
First image is a current one.
Second image is a proposed one.
Sergey, KN7K
Sergey, KN7K
4
Great idea, please also consider adding the same capability to access remotely that exists in the 2x8 antenna switch application for those of us who have to operate remotely.
Watts
K4QJZ
Thank you Dragisa.
Here is another question/idea.
Depends how is PGXL SWR bridge/Power meter built in PGXL, is there any possibility to show Power and SWR values on PGXL Utility when PGXL on Standby?
This way PGXL Utility can be used as accurate Power and SWR Meter for the radio.
Sergey, KN7K0 -
And Thank you to 4O3A team, it seems like SWR numerical value is going to be implemented in the next version.
Very quick and efficient work!
Sergey, KN7K
Sergey,
Good idea. I suggested this to the Flex personnel at last year's SeaPac convention here in Oregon.
My other amp is an SPE Expert 2K and its utility program continues to meter even when the amp is in standby. Very valuable when I am using TeamViewer to remote and can only see one of my screens at a time. (see photo)
73, Bob, N7ZO
I would like to see the power output working with SSDR in the radio panel's. At my station it only works on tune but registered NOTHING on ssb. It is worthless and even on the amp display itself doesn't show PEP correctly is way-way low. This needs to be addressed even the analog meters in my Palstar tuner reads correct and of course my LP700 but surely if the analog meter in the Palstar catches the correct PEP our $7000.00 PGXL can be made to work.
Anyone else think "PGXL auto standby" if you don't transmit for a while would be a good feature?
When PGXL is local the fan is loud and you won't forget to turn it off. When it's remote, your only reminder is highlighted text in the SSDR frame.
I'd suggest 30 minute default, configurable duration and option to disable the feature. Feature could be native to the amp OR in SSDR/Maestro software
@Asher That makes sense to me. Maybe even allow for setting the time by the user just like on computers?
Either way I'm adding this as a request right away.
Thanks! If the feature is configured in the PGXL Utility, makes SmartLink or routable access between the utility and the amp even more important.
- 384 Community Topics
- 649 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
