Flex 6400 maestro and tune button.
Joe Wussler
Hi all I have a strange problem. I have a 6400 with a  maestro. When I hit the tune button on the  maestro I am not getting a carrier to engage the plaster HF-Auto. When I load smart SDR it works fine. Both the maestro and SmartSDR are set for power output. Any ideals
In my case, when "tune" did not work, I was advised to make sure the CW "pitch" setting was set to 600 HZ. Choose CW as the mode, then go to the "transmit" menu by pressing the TX Menu knob in. Set CW pitch to 600 HZ.
Alan
WA9WUD0 -
Joe:
You stated that the power was set to the same level in SSDR and the Maestro. Just to make sure, I have to ask the following, is the "TUNE POWER" set the same in both? Tune power on the Maestro setting is accessed by pressing the "MIC Gain knob to display the TX menu. I had the same problem several years ago, it took an hour to sort it out. The Maestro "Tune Power" was set to zero, I don't know how it got there but it did.
Gayle K0FLY
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
