Winkey is not synchronized between F-key and Paddle
Uwe - DK3WW
My problem is the lack of synchronization of paddle usage (direct connected in F6600) and the function key operation ( N1MM+ actual version). When I tap the paddle, an ongoing CW output via F-keys should actually be interrupted immediately. However, that does not happen. Winkey is controlled from two sources at the same time and a PTT hanger is generated.
Smartsdr (3.1.12) uses an old Winkey emulation (V10). The current Winkey version is V31. I have now reconnected my external Winkeyer again and assigned the Com-Port and see there it works without problems.
Actually I wanted to minimize my cable mess by switching to Flexradio but...
Is there a solution that I can implement myself? If this is a bug, it should be fixed.
73! and cu in the WPX-CW
Uwe - DK3WW
Uwe - DK3WW
I dont think its a bug so to speak.. but I will validate this and if I duplicate will suggest a feature request to the team. Winkey emulation is a great feature with a few shortcomings, but its presence is certainly a great advantage of the platform. particularly in a pinch or for minimalist cabling scenarios.0
Thank you for your prompt reply. I hope you can solve the problem and possibly implement the current winkey version.
Greetings and cu in WPX
Uwe - DK3WW
I found out that is a "known" issue, when you use the paddel to send some extra chars this may confuse the radio, not knowing who is sending. I found tapping on the paddle or sending a char on the N1MM CW keyboard would "release" the transmitter... This always leads to unnecessary repetition questions in a contest.
That means the internal winkey isn't working properly. Too bad that nothing has been done for cw for a long time.
73! Uwe
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
