CW Skimmer decoding capacity creeps up to 100%
WK2Y
I don't think this is related to SmartSDR or the Flex, but I notice that when I use CW Skimmer that over time, even if I just leave it sitting, the "Decoding Capacity Used" (little icon on the bottom) creeps up to 100%. When it get's there decoding gets scrambled. Is there anyway to reset it or do I need I need to look at some settings somewhere?
Thanks and 73,
Bob
Thanks and 73,
Bob
I am running Win 64 bit, 2.9ghz (4.1 turbo) i5 9th generation, 6 core processor 16 gb of ram on a gaming motherboard, PC I built myself with programs like SSDR and CWSkimmer in mind. But in spite of what should be more then enough horse power, I still have CWSkimmer issues. If I have or have had either Google Chrome or Firefox running and start CWSKimmer with SSDR already running, 99% of the time the decoder indicator at the bottom of CWSKimmer will show red and there will be no decoding. So typically if I plan to use CWSKimmer, I will do a PC restart and then start Skimmmer and all is fine. I start CWSKimmer using Slicemaster. I have asked both the author of CWSKimmer and Slicemaster about this problem and neither are quite sure what is causing this- they feel it is more of a Windows/browser related.
Paul w2eck
Thanks. I think I'll experiment and try not running a browser or anything else and see what happens with just CW Skimmer .
BTW, I finally had to give up on SliceMaster to start running CW Skimmer. I think my issue was starting with mismatched specs, e.g., IQ speed, channel or slice. Seems like once you get off on the wrong foot, it's hard to get things started. I've been using SDR Bridge which at least lets you see if the channel is streaming and what slice it is on. Issues still arise if you try and change channels or slices, at least for me.
Thanks for the feedback. Stay safe, stay healthy.
Bob, WK2Y
I have seen this too. Even I am running 6 core i7 8850. Normally Cw skimmer show 20% load, but sometimes it is static 100%. Processor load is still pretty low. When this happend, I boot the PC.
Mika/OH6MR0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
