static ip address & using Duck DNS
Howard AE3T
My ISP has been great and has not changed my IP address for along time till this past month when it has changed 3 times. I operate my F6400 remote and am concerned that this will occur when I am away and cant re program my router, and will not be able to access my station.
I have learned about using the service of duck DNS but am very confused on how to configure it. Is there a step by step guide on how to do this for Win 10 ?
An alternative is - https://www.noip.com/ No-Ip.
Easy, reliable, and free. I've used them on and off for years.
I use a Christmas light timer to turn off power to my modem for 15min every night at 3 AM. That is another low tech solution.0
If you have an ASUS router set it up with their free DDNS. If no ASUS and your about to buy a new router anyway, check out ASUS.
URL: hostname.asuscomm.com:4994
To access your Flex do this:
Step 1, 2 and 3 WA0RCX
I used https://www.noip.com for years, back when experimenting with servers etc, It worked well for the most part.
Have you considered another option to simplify things?
Ask your ISP about options to getting a static IP? It may cost a few bucks but will eliminate the problem.
I upgraded to a higher speed fibre plan that included 2 fixed (static) IPs for a bit more than the cost of the old plan.
Another benefit we found is that we stay online when others in town loose their connection when there is a problem with getting an IP address.
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
