PTT problem with my PGXL
ka7gzr
Hello!
I interfaced my 6700 to my PGXL via the A channel and LAN PTT. It took only 10 minutes. Truly plug and play!
Now my problem. I am trying to interface my Icom IC-7850 to the PGXL. I am using the "B" channel. The PGXL reads the Band and Frequency from the 7850 just fine but doesn't see the analog PTT from the 7850. I have measured the PTT from the reed switch of the 7850 and it is providing a ground.
Thoughts?
Make sure it's in the PTT for the "b" and the input PTT NOT the output. Should work0
Wayne
The layout on the back of the PGXL is somewhat confusing. I triple check it after I make a change.
Jim0 -
Wayne,
I checked it a 4th time and you hit it on the head! I was on the output of the PGXL channel B PTT. I moved to the PTT input and it keys now.
Thanks a lot. I owe you one...
Jim0 -
Happy to help. I had a lot of trouble hooking my ICOM 7610 to this linear and someone on the community helped me. Glad it was that simple. Hope you enjoy it as much as I do.0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
