Slice Master 6000 Config File
TAC
TAC Member ✭✭
edited May 2020 in SmartSDR for Windows
Can anyone tell me where the Slice Master (v0.10.7c) config file is?  I start SM and there is nothing listed under the Launch tab.  I've previously run HRD, WSJT-X, and CW Skimmer.
I have install most of these programs on my "D:" drive so I've read I need to edit the SM config file so it can find the apps in the non-standard locations.
  • Dave Garber
    Dave Garber Member ✭✭
    edited May 2020
    I beleive the programs need to be on the same drive...   also make sure they are not running elevated ( as administrator )
  • TAC
    TAC Member ✭✭
    edited May 2020
    Found it!  :-)
    C:usersNAMEAppDataLocalK1DB0slice-master
  • Brian Denley  KB1VBF
    Brian Denley KB1VBF Member ✭✭
    edited May 2020
    Good luck.  Let me know if you are successful.  I have not been able to get it to access programs on my D drive by editing the config file as yet.
  • TAC
    TAC Member ✭✭
    edited May 2020
    Changed all the "C:" to "D:" and all the apps showed up.   Just make sure Slice Master is closed so the config file isn't write protected.
  • TAC
    TAC Member ✭✭
    edited May 2020
    Not!
