Slice Master 6000 Config File
TAC
Can anyone tell me where the Slice Master (v0.10.7c) config file is? I start SM and there is nothing listed under the Launch tab. I've previously run HRD, WSJT-X, and CW Skimmer.
I have install most of these programs on my "D:" drive so I've read I need to edit the SM config file so it can find the apps in the non-standard locations.
I beleive the programs need to be on the same drive... also make sure they are not running elevated ( as administrator )0
Found it! :-)
C:usersNAMEAppDataLocalK1DB0slice-master
Good luck. Let me know if you are successful. I have not been able to get it to access programs on my D drive by editing the config file as yet.0
Changed all the "C:" to "D:" and all the apps showed up. Just make sure Slice Master is closed so the config file isn't write protected.
Not!
- 407 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
