Mox and amplifier
Phil Holcombe
Member ✭
newbie here with 6400 and Ameritron ALS 600, when keying with Heil mic get 500 watts out, when using Mox on laptop, amp keys but no additional power, TIA for suggestions Phil
Be sure your DAX is on0
check the TX settings in the TX panel? the TX band settings from the settings menu, is your power set to low?0
On the right side of the screen where your processor and Mon buttons are, be sure that the DAX button is on ( Blue )0
Most likely not getting the laptop mic (if that is what you are using) electronically attached to the app. From SmartSDR a) make sure "PC Audio" button near the main volume controls is pressed (it turns blue) b) in the "P/CW" settings window, select "PC" for the mic, not "mic" which is the radio boxes front mic jack, telling it to use your built-in laptop mic c) as Ross Lambert pointed out in the same P/CW settings window, DAX must be pushed (it turns blue).
On the laptop, make sure the laptop mic isn't muted and the P/CW is still active so you can see your mic audio level and compression. Turn the RF power down to zero, hit the MOX and adjust the level so you are getting a line or two of compression. If you aren't seeing audio, you will need to look into the windows side of mic settings.
Starting with the most likely things not set up right. If this doesn't work, let us know there are more things that could snag up the audio, but these are the things to try first.
73 en gud lck WA7DUH
Thanks guys, the DAX and PC mic did the trick.0
You are welcome. I cannot tell you how many times I have had no output and then remember to check the DAX button! :-) Good luck and have fun! 730
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
