RX EQ, only seems to effect Slice A on the 6600M
John Orjias
just trying diversity mode and discovered the EQ only effects the main antenna on Slice A, so i turned off diversity mode and discovered it also has no effect on slice B. Is there a way to make it global for all slices that are in a Phone mode?
Try this: select slice B, change mode from what you have to something different, and then go back to the mode you were using.... This should enable RXEq on slice B0
thanks that did it, is that a bug or by design?0
Think it is a glitch that needs to be fixed, you have to wake it up0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
